2 tier server settings
Dear All,
i am using tc11.2.0
i installed corporate server, in the same machine i installed 2 tier rich client, its successfully installed, when i am trying install in another machine at 2 tier server settings tcdata location is not taking... please help in dat..
Re: 2 tier server settings
A 2tier Rich Client requires access to TC_DATA.
On the machine being installed, validate that you can ping dtcoehws194.
As the installing user, validate that you can reach \\dtcoehws194\tc_data_read_only by pasting the address in File Explorer.
On dtcoehws194, ensure tc_data_read_only is shared with "read" for "Authenticated Users".
Remember that a 2tRAC is not latency tolerant and cannot be very far away from the servers where TC_DATA and the Database live.
Evaluating: AW 3.4
