cancel
4 tier architecture- Question about Web Application and Tcserver
Hi, I am learning 4 tier archtecture.
And I set Jboss as web application server and I set 30 of Tcserver.
The GTAC references say that TcServer is used to execute business logic. But before learning web application, I thought JBOSS is used to execute program.
So I got confused about this points.
I have three questions.
Why do I need to set web application server?
If I try to see CAD files in TC, then how the JBOSS and TcServer works?
How do the JBoss choose one of the Tcserver (As I wrote here, I set 30 numbers of TcServers in TEM. What is the criteria to choose a correct TcServer? )
Could you please answer my three questions?
Re: 4 tier architecture- Question about Web Application and Tcserver
Rather than answer each question specifically, please allow me to direct you to the Teamcenter Deployment Guide: https://support.industrysoftware.automation.siemens.com/docs/teamcenter/11.2.1/TcDeploymentGuide_TcU...
Chapters 2 and 3 of this guide provide answers to these questions in great detail.
--Pat
Patrick (Pat) Kennedy, Sr. PLM Application Engineer, Acuity Solutions
Thank you so much.
I am begginner. So I could not understand which references I should read.
So I did post so many questions.
Thank you so much.
