4T webtier login issue
Siemens Creator
while doing logging in 4T webtier clinet I am geeting error related to treecaches, please fine attachment with this for more explanation,
Re: 4T webtier login issue
What are you using for the WAS? IIS, JBoss, Other?
Evaluating: AW 3.4
Siemens Creator
Jboss
What version of Teamcenter, what version of JBoss, what version of Java?
You have a configuration issue or a version problem within JBoss. The TreeCache in JBoss needs to talk to the TreeCache in J2EE Server Manager so they can share the cache information.
Evaluating: AW 3.4
Siemens Creator
TCRS 11.3
 JBoss 7.1.1
JAVA  1.7.0_45
How can we check that they are sharing cache information or not?
Did you use JBoss7_1_0_Installation_and_Tuning_Guide_v2.0.pdf (available from GTAC) to configure JBoss?
How to know ... The TreeCache info will be displayed in the jboss log when the first client connects.
Evaluating: AW 3.4
Check the ports in TreeChacheTCP.xml file in your confs/%ENVIRONMENT% folder.
