Do you mean
Reply
Solved! Go to solution
ACL - participant dynamic
I would like to know if it is possible to add ACL for a dynamic participant.
I would like to allow to modify data that are in a workflows only to the dynamic participant linked to it.
Do you have any idea ?
Best regards,
Solution
Solution
Accepted by topic author benjamin1
‎06-06-2017 08:12 AM
Re: ACL - participant dynamic
Dear Benjamin,
Dynamic participants cannot be directly used in your ACL rules. But indirectly, when the participant member(s) are assigned as Responsible Party or Approver to a workflow task, the workflow ACLs can you these accessor types to grant access.
Mahendra
