AE_create_dataset_with_id or TCTYPE_create_object not working with Teamcenter Rapid Start 11.2.3
Hi guys,
We're trying to make a customization for a customer to automatically convert UGMASTER dataset to STP and put it back to the ITEM Revision.
We are trying to use AE_create_dataset_with_id or TCTYPE_create_object but getting errors.
Are these not supported by Teamcenter Rapid Start 11.2.3?
Cem
Re: AE_create_dataset_with_id or TCTYPE_create_object not working with Teamcenter Rapid Start 11.2.3
Can you share the errors, or better the syslog?
Harish
A little long but here you are. Thanks!
INFO - 2017/05/02-16:32:55.240 UTC - NoId - POM V10.0.1.0 startup finished. - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_init.cxx(647)
ERROR - 2017/05/02-16:32:56.810 UTC - NoId - -1 - Missing session key k_am_accessor_key_regular_project_member from am_text.xml or the textsrv shared cache is stale.
- Teamcenter.Organization.sa at D:\workdir\tc1123w1205_64\src\core\sa\am_fru.cxx(490)
ERROR - 2017/05/02-16:32:56.810 UTC - NoId - -1 - Missing session key k_am_accessor_key_privileged_project_member from am_text.xml or the textsrv shared cache is stale.
ERROR - 2017/05/02-16:32:56.810 UTC - NoId - -1 - Missing session key k_am_accessor_key_team_admin_project_member from am_text.xml or the textsrv shared cache is stale.
ERROR - 2017/05/02-16:32:56.810 UTC - NoId - -1 - Missing session key k_am_accessor_key_administrator_project_member from am_text.xml or the textsrv shared cache is stale.
INFO - 2017/05/02-16:32:56.833 UTC - NoId - library libqry is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:56.834 UTC - NoId - locking "Metadata-Master"; filepath "C:\Users\ADMINI~1.BOR\AppData\Local\Temp\1\V11000.2.0.30_20161205.00\2371941657\Metadata" - Teamcenter.MetaModel.sharedcache at D:\workdir\tc1123w1205_64\src\core\sharedcache\SharedMetadataMasterSegmentMgr.cxx(166)
INFO - 2017/05/02-16:32:56.835 UTC - NoId - allocate segment "C:\Users\ADMINI~1.BOR\AppData\Local\Temp\1\V11000.2.0.30_20161205.00\2371941657\Metadata\Master.mem" (size 1KB) using mutex "sers_ADMINI~1.BOR_AppData_Local_Temp_1_V11000.2.0.30_20161205.00_2371941657_Metadata_Master.seg.mtx" - Teamcenter.MetaModel.sharedcache at D:\workdir\tc1123w1205_64\src\core\sharedcache\SharedMetadataMasterSegmentMgr.cxx(183)
INFO - 2017/05/02-16:32:56.835 UTC - NoId - Constructed SharedMetadataMasterSegmentMgr instance @ 0000002C4524DFE0, mapping from 0000002C45850000 through 0000002C45850FFF - Teamcenter.MetaModel.sharedcache at D:\workdir\tc1123w1205_64\src\core\sharedcache\SharedMetadataMasterSegmentMgr.cxx(224)
INFO - 2017/05/02-16:32:56.837 UTC - NoId - metadata dataset version [7] metadata DB change version [7] - Teamcenter.MetaModel.sharedcache at D:\workdir\tc1123w1205_64\src\core\sharedcache\SharedMetadataCacheMgr.cxx(156)
INFO - 2017/05/02-16:32:56.837 UTC - NoId - Constructed SharedMetadataCacheSegmentMgr instance @ 0000002C43DCD0B0 for version 7, mapping from 0000002C45860000 through 0000002C4BC13FFF - Teamcenter.MetaModel.sharedcache at D:\workdir\tc1123w1205_64\src\core\sharedcache\SharedMetadataCacheSegmentMgr.cxx(76)
INFO - 2017/05/02-16:32:56.837 UTC - NoId - Initialized SharedMetadataCacheMgr with SharedMetadataCacheSegmentMgr @ 0000002C43DCD0B0 for version 7 in [C:\Users\ADMINI~1.BOR\AppData\Local\Temp\1\V11000.2.0.30_20161205.00\2371941657\Metadata] - Teamcenter.MetaModel.sharedcache at D:\workdir\tc1123w1205_64\src\core\sharedcache\SharedMetadataCacheMgr.cxx(260)
INFO - 2017/05/02-16:32:56.934 UTC - NoId - Using Shared memory, MetadataCache @ 0000002C43E15EC0 - Teamcenter.MetaModel.sharedcache at D:\workdir\tc1123w1205_64\src\core\sharedcache\MetadataCache.cxx(75)
INFO - 2017/05/02-16:32:56.935 UTC - NoId - library libbmf is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:56.935 UTC - NoId - library libextensionframework is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:57.239 UTC - NoId - ItemRevision||updateThumbnailOnSaveAsAndRevise||ITEM_deep_copy - Teamcenter.MetaModel.bmf
INFO - 2017/05/02-16:32:57.648 UTC - NoId - Default encryption configuration. - Teamcenter.FoundationBase at D:\workdir\tc1123w1205_64\src\foundation\base\Crypto.cxx(106)
Successfully loaded dynamic module D:\PLM\tcdata\Creas\Creas_custom_handlers_TC11_BOREAS.dll
INFO - 2017/05/02-16:32:57.734 UTC - NoId - POM_login: "infodba" infodba / dba has logged in - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_start.cxx(1296)
INFO - 2017/05/02-16:32:57.790 UTC - NoId - library libFnd0disclosure is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
Successfully loaded dynamic module D:\PLM\TC11\bin\libFnd0disclosure.dll
NOTE - 2017/05/02-16:32:57.790 UTC - NoId - TC_AM_user_init: Invoking Customize_Access_Manager callback - Teamcenter.Organization.sa at D:\workdir\tc1123w1205_64\src\core\sa\am_fru.cxx(3679)
NOTE - 2017/05/02-16:32:57.828 UTC - NoId - EIM_does_table_exist: #POM_uid_scratch2 is not there - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\eim\eim_tables.cxx(877)
INFO - 2017/05/02-16:32:57.936 UTC - NoId - library libFnd0editcontext is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
Successfully loaded dynamic module D:\PLM\TC11\bin\libFnd0editcontext.dll
************** Licensing Information **************
Sold To / Install : 1543684 - Boreas Muhendislik ve
Webkey Access Code : 60AFPZCPVA
License File Issuer : SIEMENS
Flexera Daemon Version : 11.13
Vendor Daemon Version : 8.2
Toolkit Version : 8.2.1.4
Server Setting Used : 28000@appsrv
Server Setting Came From The 'SPLM_LICENSE_SERVER' Environment Variable.
Number of bundles in use : 0
INFO - 2017/05/02-16:32:57.981 UTC - NoId - library libdocmgt is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:57.982 UTC - NoId - library librbf is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:57.986 UTC - NoId - library libepm is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:57.988 UTC - NoId - library libres is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
POM_session_no_stub_reference called for WorkspaceObject:release_status_list
INFO - 2017/05/02-16:32:57.999 UTC - NoId - library libbom is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.003 UTC - NoId - library libecm is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.005 UTC - NoId - library libme is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.007 UTC - NoId - library libmfg is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.015 UTC - NoId - library libmfgbvr is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
Successfully loaded dynamic module D:\PLM\TC11\bin\libmfgbvr.dll
INFO - 2017/05/02-16:32:58.021 UTC - NoId - library libqsearch is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
Successfully loaded dynamic module D:\PLM\TC11\bin\libsa.dll
INFO - 2017/05/02-16:32:58.050 UTC - NoId - library libFnd0audit_mgr is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
Successfully loaded dynamic module D:\PLM\TC11\bin\libFnd0audit_mgr.dll
INFO - 2017/05/02-16:32:58.055 UTC - NoId - library libsub_mgr is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
Successfully loaded dynamic module D:\PLM\TC11\bin\libsub_mgr.dll
POM_session_no_stub_reference called for Dataset:rev_chain_anchor
INFO - 2017/05/02-16:32:58.415 UTC - NoId - library libform is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.417 UTC - NoId - library libcollabctx is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.435 UTC - NoId - library libce is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.442 UTC - NoId - library libusage is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.449 UTC - NoId - library libai is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.578 UTC - NoId - library libappr is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.616 UTC - NoId - library libcfm is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.618 UTC - NoId - library libfnd0booleansolve is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
Successfully loaded dynamic module D:\PLM\TC11\bin\aciClient.dll
NOTE - 2017/05/02-16:32:58.625 UTC - NoId - FTS: The FTS IDOL engine or FSF could not be found. - Teamcenter.Search.qry at D:\workdir\tc1123w1205_64\src\core\qry\autonomy_utils.cxx(543)
INFO - 2017/05/02-16:32:58.631 UTC - NoId - library libpublication is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.640 UTC - NoId - library libvalidation is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.647 UTC - NoId - library libgrm is delay loaded - Teamcenter.Metamodel.MetaFrameWork at D:\workdir\tc1123w1205_64\src\core\metaframework\BusinessObjectRegistryImpl.cxx(2466)
INFO - 2017/05/02-16:32:58.649 UTC - NoId - locking "LOV-Master"; sharedMemDir "C:\Users\ADMINI~1.BOR\AppData\Local\Temp\1\V11000.2.0.30_20161205.00\2371941657\LOV" - Teamcenter.LOV at D:\workdir\tc1123w1205_64\src\core\lov\SharedLOVDictionaryCacheImpl.cxx(124)
INFO - 2017/05/02-16:32:58.650 UTC - NoId - allocate segment "C:\Users\ADMINI~1.BOR\AppData\Local\Temp\1\V11000.2.0.30_20161205.00\2371941657\LOV\Master.mem" (size 1KB) using mutex "C:_Users_ADMINI~1.BOR_AppData_Local_Temp_1_V11000.2.0.30_20161205.00_2371941657_LOV_Master.seg.mtx" - Teamcenter.LOV at D:\workdir\tc1123w1205_64\src\core\lov\SharedLOVDictionaryCacheImpl.cxx(155)
INFO - 2017/05/02-16:32:58.652 UTC - NoId - Attached to existing shared LOV Dictionary pool (0000002C45494990) version 1 - Teamcenter.LOV at D:\workdir\tc1123w1205_64\src\core\lov\SharedLOVDictionaryCacheMgr.cxx(195)
INFO - 2017/05/02-16:32:58.654 UTC - NoId - Started. - Teamcenter.CoreModelGeneral.tc at D:\workdir\tc1123w1205_64\src\core\tc\infomanager.cxx(322)
INFO - 2017/05/02-16:32:58.654 UTC - NoId - Teamcenter version is: Teamcenter V11000.2.3.30_20161205.00 - Teamcenter.CoreModelGeneral.tc at D:\workdir\tc1123w1205_64\src\core\tc\infomanager.cxx(361)
INFO - 2017/05/02-16:32:58.654 UTC - NoId - Preference Autotest_Security_Level does not exist. Totally Secure level 1 is used by default. - Teamcenter.Organization.sa at D:\workdir\tc1123w1205_64\src\core\sa\ImanVolumeImpl.cxx(4392)
INFO - 2017/05/02-16:32:58.654 UTC - NoId - Security Level = 1 - Teamcenter.CoreModelGeneral.tc at D:\workdir\tc1123w1205_64\src\core\tc\infomanager.cxx(364)
INFO - 2017/05/02-16:32:58.654 UTC - NoId - NX library version V4.0.0.2016041300 - Teamcenter.CoreModelGeneral.tc at D:\workdir\tc1123w1205_64\src\core\tc\infomanager.cxx(365)
INFO - 2017/05/02-16:32:58.656 UTC - NoId - EFFECTIVITY MODEL: V7 - Teamcenter.CoreModelGeneral.tc at D:\workdir\tc1123w1205_64\src\core\tc\infomanager.cxx(379)
INFO - 2017/05/02-16:32:58.656 UTC - NoId - Current POM environment information: - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3410)
INFO - 2017/05/02-16:32:58.656 UTC - NoId - Timeout: Strategy 4001 Interval 5 - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3411)
INFO - 2017/05/02-16:32:58.656 UTC - NoId - POM AM bypass: DISABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3414)
INFO - 2017/05/02-16:32:58.656 UTC - NoId - Wildcards: one "?" any "*" - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3417)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Transmit dir: D:\PLM\tcdata\pom_transmit - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3418)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Rollback: DISABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3419)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - DS checking: DISABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3420)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Argument checking: ENABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3421)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Journalling: DISABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3422)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Tracebacks: DISABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3423)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Logging SQL: DISABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3424)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Attr update: ENABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3425)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Import mode: 13004 - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3426)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Import user: 00000000 - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3427)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Import group: 00000000 - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3428)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - API state: ENABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3429)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Uniqueness check: DISABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3430)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Set Attr callbacks: DISABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3431)
INFO - 2017/05/02-16:32:58.684 UTC - NoId - Timestamp updates: DISABLED - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_most_interface_funs2.cxx(3432)
NOTE - 2017/05/02-16:32:58.719 UTC - NoId - envUpgradeMode = - Teamcenter.CoreModelGeneral.tc at D:\workdir\tc1123w1205_64\src\core\tc\check_license.cxx(4902)
NOTE - 2017/05/02-16:32:58.719 UTC - NoId - envInstallMode = - Teamcenter.CoreModelGeneral.tc at D:\workdir\tc1123w1205_64\src\core\tc\check_license.cxx(4903)
NOTE - 2017/05/02-16:32:58.733 UTC - NoId - envUpgradeMode = - Teamcenter.CoreModelGeneral.tc at D:\workdir\tc1123w1205_64\src\core\tc\check_license.cxx(4902)
NOTE - 2017/05/02-16:32:58.733 UTC - NoId - envInstallMode = - Teamcenter.CoreModelGeneral.tc at D:\workdir\tc1123w1205_64\src\core\tc\check_license.cxx(4903)
Creas Login Successful...
INFO - 2017/05/02-16:32:58.784 UTC - NoId - ** The MultiFieldKeyAttrsMap has 4 entries. - Teamcenter.Metamodel.constants at D:\workdir\tc1123w1205_64\src\core\constants\typeconstantcache.cxx(835)
Successfully loaded dynamic module D:\PLM\TC11\bin\libNX0tcin.dll
NOTE - 2017/05/02-16:33:25.860 UTC - NoId - called for zero ifail - Teamcenter at D:\workdir\tc1123w1205_64\src\foundation\base_utils\ErrorStoreBase.cxx(616)
dms_load::check_stub_exists RevisionAnchor tag 000082b9 goPAAACcYbwXRC not of a DB pom object, nor a stubbed object
by the way this UID was allocated in this session, did you then delete it?
goPAAACcYbwXRC is not in table PREVISIONANCHOR
goPAAACcYbwXRC is not in table PPOM_APPLICATION_OBJECT
goPAAACcYbwXRC is not in table PPOM_OBJECT
goPAAACcYbwXRC is not referenced from anything in the database
NOTE - 2017/05/02-16:33:25.868 UTC - NoId - called for zero ifail - Teamcenter at D:\workdir\tc1123w1205_64\src\foundation\base_utils\ErrorStoreBase.cxx(616)
ERROR[9138] : Can not initialize dataset %1$s
(file: Creas_command_line_utility.cpp, line:216)
Note that the ITK_user_main program has logged in, but never logged out before returning
NOTE - 2017/05/02-16:33:25.917 UTC - NoId - RIL_tidy_foreign_locks find [4] f-locks - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\ril\ril_foreign.cxx(130)
INFO - 2017/05/02-16:33:25.919 UTC - NoId - POM shutdown complete. - Teamcenter.POM at D:\workdir\tc1123w1205_64\src\foundation\pom\pom\pom_init.cxx(346)
UNDO - Deleting some marks on resetting markpoint limit marks 2 limit 1
POM enquiries statistics: created 137, undone 1, deleted 95, queried 434
@@@ End of session Tue May 02 19:33:25 2017 Turkey Standard Time
