AM_RULE_TEST_HARNESS searchCriteria for Dataset
Can anyone share what is search criteria for Dataset, ProPart, Proasm, PDF & Excel.
I want to test CREO Partfile, Assembly, JT File, PDF File & Excel file access using Access Manager Rule Harness test.
searchCriteria
Below I tested but giving error.
searchCriteria="Dataset{object_name=BO145064}"
searchCriteria="ProPrt{object_name=BO145064}"
Jimesh Makwana,
System Administrator (New to PLM)
TC 11.4
Re: AM_RULE_TEST_HARNESS searchCriteria for Dataset
No idea. You'll have to provide more detail on your process and business need.
Issue is resolved by using below searchCriteria.
searchCriteria="Dataset{object_name=1002121,object_type=ASM}">
searchCriteria="Dataset{object_name=1002122,object_type=DWG}">
searchCriteria="Dataset{object_name=1002123,object_type=PRT}">
searchCriteria="Dataset{object_name=1002124,object_type=PDF}">
Jimesh Makwana,
TC 11.4
