AM_RULE_TEST_HARNESS
In the XML Definitions of a Usertest you have to define a Search Criteria.
I assume it is using 1 of the Standard Queries in Teamcenter.
If I define a SearchCriteria ="Dataset.... ,UGMASTER and UGSPART are found., but if I define SearchCriteria =UGMASTER the results gives: No Object found for given search criteria
I tried the same by using OOTB Queries in Teamcenter it gives me the correct Data.
Are there members of this Forum who are using this Utility?
Kind regards,
Menk Slot
1 REPLY 1
Re: AM_RULE_TEST_HARNESS
I found the solution:
The searchCriteria needs to be Dataset, because the class is Dataset.
To separate UGMASTER and UGPART or other dataset types, a value in the ObjectDescription could be given
Example: searchCriteria=Dataset{object_desc=InProject_UGMASTER}
