AM_RULE_TEST_HARNESS
In the XML Definitions of a Usertest you have to define a Search Criteria.
I assume it is using 1 of the Standard Queries in Teamcenter.
If I define a SearchCriteria ="Dataset.... ,UGMASTER and UGSPART are found., but if I define SearchCriteria =UGMASTER the results gives: No Object found for given search criteria
I tried the same by using OOTB Queries in Teamcenter it gives me the correct Data.
Are there members of this Forum who are using this Utility?
Kind regards,
Menk Slot
Re: AM_RULE_TEST_HARNESS
I found the solution:
The searchCriteria needs to be Dataset, because the class is Dataset.
To separate UGMASTER and UGPART or other dataset types, a value in the ObjectDescription could be given
Example: searchCriteria=Dataset{object_desc=InProject_UGMASTER}
