AWC 3.4 Indexing failing
Hello
I recently patched from AWC3.3 to 3.4 (with TC11.3). After that the object indexing is failing.
I have merged solr schemas, and tried to reindex it all. I've also cleared the index to start indexing from scratch.
I have 140.000+ objects in my database. From some reason I successfully managed to index 2600 of them. But no luck with the remaining objects.
The tcftsindexer_objdata.log shows this summary after running index command:
2017-12-21 16:43:39,638 INFO - ----------------------------------------------------------------------------------------------------
2017-12-21 16:43:39,638 INFO - Status: Created: 0 Started: 0 Done: 218 Error: 0
2017-12-21 16:43:39,638 INFO - Total Time 5,82 Total Count 143373
2017-12-21 16:43:39,638 INFO - Step Summary
2017-12-21 16:43:39,638 INFO - objdataquerystep
2017-12-21 16:43:39,638 INFO - Status: Created: 0 Started: 0 Done: 200 Error: 0
2017-12-21 16:43:39,638 INFO - Total Time 334,80 Total Count 143373
2017-12-21 16:43:39,638 INFO - objdataexportstep
2017-12-21 16:43:39,638 INFO - Total Time 1052,47 Total Count 143373
2017-12-21 16:43:39,638 INFO - objdatasaxtransformstep
2017-12-21 16:43:39,638 INFO - Total Time 15,52 Total Count 143373
2017-12-21 16:43:39,654 INFO - objdataloadstep
2017-12-21 16:43:39,654 INFO - Status: Created: 0 Started: 0 Done: 218 Error: 0
2017-12-21 16:43:39,654 INFO - Total Time 5,82 Total Count 143373
2017-12-21 16:43:39,654 INFO - Total time for all Steps 1409 sec
2017-12-21 16:43:39,654 INFO - Overall Time 366.781 sec
2017-12-21 16:43:39,654 INFO - Done processing Type: objdata FlowAction: index
Looking at the syslog i'm repeatedly getting these errors every time the clause count has reached 1200 or so
INFO - 2017/12/21-15:41:03.683 UTC - 192.168.50.54.30322.infodba.00049.Svr - Clause[1222] = CLASS.smlb0:PROPERTY.wac:DO - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:03.683 UTC - 192.168.50.54.30322.infodba.00049.Svr - Clause[1223] = CLASS.Awb0BOMIndexAdminData:PROPERTY.awb0Product:DO - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:03.683 UTC - 192.168.50.54.30322.infodba.00049.Svr - Clause[1224] = CLASS.Awb0BOMIndexAdminData:PROPERTY.awb0BaseRevisionRule:DO - Teamcenter.GMS.tie
NOTE - 2017/12/21-15:41:03.683 UTC - 192.168.50.54.30322.infodba.00049.Svr - getPointee_s() TYPE_unknown_type for typetag = 10832
- Teamcenter at D:\workdir\tc11301_a01_win64\src\core\tccore/ImanTypeCacheRef.hxx(218)
NOTE - 2017/12/21-15:41:03.699 UTC - 192.168.50.54.30322.infodba.00049.Svr - getPointee() TYPE_unknown_type for typetag = 10832
- Teamcenter at D:\workdir\tc11301_a01_win64\src\core\tccore/ImanTypeCacheRef.hxx(188)
NOTE - 2017/12/21-15:41:03.699 UTC - 192.168.50.54.30322.infodba.00049.Svr - Got error 39014 - Teamcenter.CoreModelGeneral.tccore at D:\workdir\tc11301_a01_win64\src\core\tccore\ImanTypeCache.cxx(4637)
ERROR - 2017/12/21-15:41:03.699 UTC - 192.168.50.54.30322.infodba.00049.Svr - 39014: The specified type does not exist - TIE error (The specified type %1$s does not exist) - Teamcenter.GMS.tie
NOTE - 2017/12/21-15:41:03.699 UTC - 192.168.50.54.30322.infodba.00049.Svr - getPointee_s() TYPE_unknown_type for typetag = 14174
NOTE - 2017/12/21-15:41:03.699 UTC - 192.168.50.54.30322.infodba.00049.Svr - getPointee() TYPE_unknown_type for typetag = 14174
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - [Session Option Name] [Session Option Value] - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - applicationID :FTS_SYNC - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - fastStream True - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - forceRetraverse True - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - opt_bypass_pom_space_version_block True - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - opt_delete_logs on-success - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - opt_delete_transient_files True - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - opt_exp_TraverseRootRefs True - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - opt_ics_incl_props True - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - opt_lbr_process_ancestors True - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - processAMRules True - Teamcenter.GMS.tie
INFO - 2017/12/21-15:41:05.418 UTC - 192.168.50.54.30322.infodba.00049.Svr - processLOVDisplayValues True - Teamcenter.GMS.tie
***Traversal Record(Memory:SQL:Time:)***Memory : 2943879 ,SQL: 2176 ,TIME: 0.766000s cpu, 2.047000s real
NOTE: Performance Metrics for LL TC XML export traversal:
SM Memory Usage(bytes): 2944471
Total Memory Usage(bytes): 5865472
Peak Memory Usage(bytes): 289210368
CPU time(seconds): 1.063000
Real time(seconds): 3.063000
DB Trips: 3187
NOTE - 2017/12/21-15:41:05.730 UTC - 192.168.50.54.30322.infodba.00049.Svr - getPointee_s() TYPE_unknown_type for typetag = 9612
NOTE - 2017/12/21-15:41:05.746 UTC - 192.168.50.54.30322.infodba.00049.Svr - getPointee() TYPE_unknown_type for typetag = 9612
NOTE - 2017/12/21-15:41:05.746 UTC - 192.168.50.54.30322.infodba.00049.Svr - Got error 39014 - Teamcenter.CoreModelGeneral.tccore at D:\workdir\tc11301_a01_win64\src\core\tccore\ImanTypeCache.cxx(4637)
INFO - 2017/12/21-15:41:05.746 UTC - 192.168.50.54.30322.infodba.00049.Svr - FATAL - TCpool-1-thread-128_851513870862574-TIEFastExporter - 2017-12-21 16:41:05,000 - mt-tcapp03 - ### Error 39014 : In TIEFastExportSerializer::getClassCompoundProperties
- Teamcenter.GMS.gms at D:\workdir\tc11301_a01_win64\src\core\gms\syslogappender.cxx(19)
INFO - 2017/12/21-15:41:05.746 UTC - 192.168.50.54.30322.infodba.00049.Svr - FATAL - TCpool-1-thread-128_851513870862574-TIEFastExporter - 2017-12-21 16:41:05,000 - mt-tcapp03 - ### Error 39014 : In TIEFastExportSerializer::buildAttributeMap
***Serialize Record(Memory:SQL:Time:)***
Memory : 39 ,SQL: 13 ,TIME: 0.062000s cpu, 0.140000s real
NOTE: Performance Metrics for LL TC XML export traversal plus serialize:
SM Memory Usage(bytes): 3282211
CPU time(seconds): 1.140000
Real time(seconds): 3.985000
DB Trips: 3214
The recover and the indexsyncfailures options don't make any difference. They are both stating that they find 140k objects, but they don't do anything to them.
Re: AWC 3.4 Indexing failing
I stopped all TC and solr services and killed all TC processes, deleted V11000xxx cache folders in %temp% (both in \temp and \temp\2 folder), and restarted system.
After that the indexing completed without errors.
Hi ,
I had faced a problem like you on AWC 3.4 . I think there is a specific problem about the indexing engine for AWC 3.4. I solved it cleaning the all related caches and clean indexing file then reindexing all it .
Best Regards
Gurkan
