AWC: How to create Basedline object
Hi, in OOTB enviroment, Is it possible to create TC_basedline object?
I could not find the menu for it.
Could you someone help me out?
Re: AWC: How to create Basedline object
To create baseline item revisions, it needs to define the seperate workflow for the same.
You can find the information about it in the 'Workflow Designer" guide.
Look for the Creating baseline workflow process templates in the document.
