AWC: How to see TC_Basedlined Object
In the TC rich client, the users created TC_Baselined object and I want to know how to TC_Baselined object.
I can just see the assembly with revision rule.
My questions is:
①In AWS, How can you see the TC_Baseline object? If there is no way to do that, how should I do the configuration for it?
Re: AWC: How to see TC_Basedlined Object
Open Item > Overview tab > Revisions
Baseline revision should display under the 'Revisions' section of the overview tab.
Ganesh Kadole, QA Analyst (PLM), SQS
Testing: NX 11 | NX 12 | TCIN
TC 11.2 | TC Vis 11.3 | AWC 3.2
Thank you for the reply.
In the Rich client, there are TC_BASELINE Object. There is no serach criteria on AWS Userinterface. How do you find TC_Basedline object on AWS?
