AWC Item Creation via customization
Hi All,
I am new in AWC Customization. Anybody have an idea that how to create item or (any type of business objects) via AWC customization using code.
i Will be grateful if anybody give me idea/hint for creating an item using code in AWC.
Vinita
Re: AWC Item Creation via customization
@Vinita, Please let know, if you find any sources files on AWC customization .
There are plenty of examples in the AWC content itself. Have you installed AWC and reviewed the declarative customization in AWC help? Especially helpful is the XRT Editor.
https://docs.plm.automation.siemens.com/tdoc/aw/4.1/aw_html_collection/#uid:xid1284832:index_Configu...
Note: I've only recently started using AWC 4.1 where there was a major UI change from previous versions.
Evaluating: AW 3.4
