AWC Search Bar Configuration
Hi folks,
I'd like to change which properties are being searched by the search bar at the top right of AWC. Specifically, I'd like to add a custom property from a custom Item subtype.
I've gone through the AW documentation, but I haven't been able to figure it out.
Any guidance would be appreciated.
-Aaron
TCRS 11.4
AWC 3.3
Re: AWC Search Bar Configuration
You can configure this in the BMIDE.
You can choose which business objects and also which properties will be indexed.
If you want search by a certain property you have to the business object constant and the property constant "Awp0SearchIsIndexed" to "true".
The constant "Awp0SearchCanFilter" has to be acitvated when you want that the property can be filtered in the facets.
After you changed it and redeployed TC, you have to update the SOLR Schema and reindex everything.
