AWC display problem
Hello everybody,
We use https and SSO. TC11.3 AWC 4.0.3
When I connect to active workspace, on the login page I do not have the choice of the language. Once connected I am well connected to the AWC server but with a white page, we can see at the top that my user is not indicated!
When I pass my Internet Explorer in English it works.
An idea to leave my IE in French?
pas choix lang.pngNo language choiceusermanquant.pngno user indicated / white page
changelangue.pngIf I put English on the top its working
5 REPLIES 5
Re: AWC display problem
I don't know how you've configured your SSO but :
1. Have you deployed the language "French" in SSO ?
2. On the server where you're building the AWC war, did you specify your SSO settings ? (I'm think about the "Active Workspace Client Settings" panel)
Best regards,
Frédéric.
Hello @FLehn,
Thank you for your reply :)
I configured the SSO on tomcat (We are using IIS,reverse proxy and https)
1. Have you deployed the language "French" in SSO ? Yes
2. On the server where you're building the AWC war, did you specify your SSO settings ? Yes I did
Any idea ?
Ok ! Did you try with another browser and/or clean the cache of IE ?
@FLehn,
Yes with the same result.
Hi everybody, hi @FLehn,
Any other idea ?
