AWC : "Context "function and How to look for top part from child parents.
When I look at the relation tab in OOTB AWC, Actually I can see entire BOM structure from child parts (bottom parts). But customer request that they want to see only related parents part from the child part like impact analysis in Rich client.
For example :  There is 4 level structure.
 Top
  |___ Assembly01
                 |____Assembly02
                                        |______Par
In this case, customer want to find only top part "Top" from "Part". Is there any way to look for only top level part from bottom parts in OOTB AWC.
Actually there are one function "context" in Attachment tab in AWC. I don't know how to use it. If this is used, do we have to do some configurations for the use of "context"
Re: AWC : "Context "function and How to look for top part from child parents.
Hi Gimac,
        The way I use AWC to see a structure in AWC is in content tab.
        1) The first search for required part
        2) Then select & open that part
        3) Click on content tab it directly shows parent part of assembly, however, I have not tried with multilevel assembly structure
Hope this helps !!
Saurabh
Thank you.
But in the content tab, it displayed only child parts, not Top level.
Did you do some configuration to display top part from child parts?
