Abort or delete old WF processes
does anybody know if there is a way to finish or abort old workflow processes? I need to finish or abort WF processes until 2013 because they are already obsolete so they are not shown in users worklist anymore.
Re: Abort or delete old WF processes
You could find all Item Revs that have in-process workflows with the OOTB "WF - Object In Process" query, then delete the unfinished workflow processes in Impact Analysis.
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
