About BMIDE Custom Item
I have created a custom item in BMIDE Teamcenter Rapid Start (10.1). i am able to deploy successfully. However this custom item which i created is not displyed in the Teamcenter (File->New Item). I have cleared the cache. I checked in the Model.xml, the custom is shown. But not getting displayed in Teamcenter. Please help me to resolve. Thanks.
Re: About BMIDE Custom Item
Please check where exactly you have created this Custom Item in BMIDE. For E.gPOM_application_object> WorkspaceObject_object>Item>Part.
In this case, the custom item is available for creation under File > New > Part > New Part Dialog box > Custom Item.
Or, Press Ctrl +H to see all the business objects and you can see the custom item type.
Hope this helps !
Cheers !
Teamcenter 10.1.7
TC Visualization 10.1.7
NX:11.02 | NX 9.02 | Catia V5 R2012 | AutoCAD 2018 | In-Context Editor |
Pls check any ACL restriction being applied on that CustomItem.
Also check type-display rules on custom Item.
