Acknowledgement Dialog at Login
Hello all,
Does anyone know of a way to create an acknowledgement dialog to pop up at the time of user login for 2-tier RAC?
We wish to create a pop up containing IP statements for example, to which the user would have to acknowledge and agree to, before proceeding with login.  A popup dialog similar to the one which appears if a select group or user does not have write access to any volumes.
Thanks in advance!
-Jake
Jake
4 REPLIES 4
Re: Acknowledgement Dialog at Login
I think you are referring to a Banner?
You can configure the server to display a notice and consent logon banner when a user connects to a Teamcenter client using smart card or soft certificate authentication. Teamcenter displays the notice defined by the banner.txt file in the login service WAR file. This file is located in the root folder of the Login Service WAR file. If the banner.txt file is empty or contains only whitespace characters, Teamcenter does not display the notice. The consent to log on dialog box provides a cancel button. If the user clicks Cancel , the connection to Teamcenter is prohibited.
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help/#uid:xid347812
Evaluating: AW 3.4
Supports multi-language also...
https://docs.plm.automation.siemens.com/tdoc/tc/11.4/help/#uid:xid604961
Evaluating: AW 3.4
Thanks for your response @RandyEllsworth!
Does this mean that Security Services and SSO must be configured within your environment?
-Jake
Jake
Yes. The Login Service contains the logon_banner.zip.
Evaluating: AW 3.4
