Active User Query
Hello all,
Does anyone know of a way to see a list of users which are currently logged into the database?  Perhaps a user query or something you can run before performing maintenance?
Thanks in advance!
Jake
Re: Active User Query
OOTB utility - list_users
Thanks and Regards
Yogesh Fegade
In the Rich Client use the menu pick, View > Current Users. As a dba, you can even clear dead sessions with this pick.
Evaluating: AW 3.4
In the Rich Client use the menu pick, View > Current Users. As a dba, you can even clear dead sessions with this pick.CurrentUsers.pngView > Current Users
Evaluating: AW 3.4
why current user list same user many times?
Because the user session has either crashed or the person behind the keyboard has closed/killed it without using File > Exit as is normal. Clearing dead sessions should clean this up.
Evaluating: AW 3.4
after purging dead session, still I see the issue
Then you'll need to contact GTAC (or your partner) to find out why those sessions are still valid or why the dead sessions cannot be removed.
After business hours, try running this in a Teamcenter command prompt after shutting down the server manager service:
clearlocks -assert_all_dead -u=infodba -p=infodba -g=dba
Then startup the server manager service and try your test again.
Evaluating: AW 3.4
Thank you, I will try.
