Active Workspace - showing content of pseudo folders
I have a problem viewing pseudo folder content in Active Workspace.
I have a revision with Documents pseudo folder. In this folder is a pdf document or a word document.
When I want to view this document in Active Workspace it is not visible under ItemRevision attachments tab.
Did anybody had the same problem or does anybody know how to show pseudo folders or its content in Active Workspace? I presume that it can be done with customization I just do not know how to do this.
Thanks.
Re: Active Workspace - showing content of pseudo folders
You should modify stylesheet to view pseudolder in AWC client.
I have attached you the document, this should work.
Rafa
Thanks Rafa2,
You have pointed me to the right direction. I have created new section (Pseudo folder name) and added pseudo folder relation in object set. Bellow is example if somebody will need it.
<section titleKey="Documents PF">
<objectSet source="PF_Relation_name.Dataset" sortdirection="ascending" sortby="object_string" defaultdisplay="listDisplay">
<tableDisplay>
<property name="object_string"/>
<property name="object_type"/>
<property name="release_status_list"/>
<property name="date_released"/>
<property name="owning_user"/>
</tableDisplay>
<thumbnailDisplay/>
<treeDisplay>
</treeDisplay>
<listDisplay/>
<command actionKey="newBusinessObjectContextualAction" commandId="com.teamcenter.rac.common.AddNew" renderingHint="commandbutton"/>
<command actionKey="pasteAction" commandId="com.teamcenter.rac.viewer.pastewithContext" renderingHint="commandbutton"/>
<command actionKey="cutAction" commandId="org.eclipse.ui.edit.cut" renderingHint="commandbutton">
<parameter name="localSelection" value="true"/>
</command>
</objectSet>
</section>
