Active workspace installation error
Builder
Builder
Dear all,
I got this error while I was trying to install active workspace 3.2.3:
The following command returned a value of 1
"install_runner.bat" -u=infodba -p=***** -g=dba -templates=aws2
I will be happy if anyone has a suggestion for me to find the problem.
We use Teamcenter 11.2.3
Sina Shojaee
Re: Active workspace installation error
Are you using Deployment Center to install AW?
Evaluating: AW 3.4
Builder
Builder
Dear @RandyEllsworth
Thank you for your attention. Actually we don't use deployment center to install AWS.
Sina Shojaee
Use DC to avoid errors installing AW.
Evaluating: AW 3.4
Have you tried runnning the command in a TC command prompt?
Builder
Builder
Thank you @RandyEllsworth . I will try DC and tell you the result.
Sina Shojaee
I ran into the following error also:
"install_runner.bat" -u=infodba -p=***** -g=dba -templates=aws2,aut0authorizationaws,activeworkspacebom
I was able to correct this by adding these values to the USER variables
  • JAVA_HOME=C:\Program Files\Java\jdk1.8.0_91
  • JRE_HOME=C:\Program Files\Java\jre8
  • JRE64_HOME=C:\Program Files\Java\jre8
I had these previously set only to the SYSTEM variables....and would receive the error while in this state
