ActiveworkSpace Integration with Solidworks doesn't work
Hello All
I set ActiveworkspaceHosting.SW2.URL
and set Activeworkspace enable=true
but when I open solidworks
It doesn't work!
Where I need to check?
Or something I miss?
thanks a lot
Best regards
Teamcenter 11.2.3,Active Workspace 3.2
Solid Edge ST10
Re: ActiveworkSpace Integration with Solidworks doesn't work
I there!
Does Active Workspace run OK on this system?
What Version of SWIM are you using?
Check the value of the URL in your Teamcenter Preferences.
ActiveWorkspaceHosting.Sw2.URL: The Integration’s server installation process adds this preference and assigns a placeholder value of http://<CHANGE_ME_HOST>:<CHANGE_ME_PORT>/awc. Customers who deploy Active Workspace for SolidWorks data management must replace this value with the appropriate values for their site.
So, if you changed this value after installing the SWIM serverside, that might be a problem.  I'm kinda guessing here... Let me know what you find.
- Peter Heath - PLM Business Development Manager
ITI - Siemens Development and Solution Partner
Hello PeterH
My machine install SE、NX、INV、SE、ACD,only SW cann't see AWC
SW Version is 2016
SWIM Version is 11.3.0
ActiveWorkspaceHosting.Sw2.URL is allready check! It's OK!
Solid Edge ST10
What is the Browser you are trying to use?
Check the spelling of the property in the properties file that enables AW embedded.
Do you see anything in the txdlog.txt or client_socket.log files?
Hello PeterH
I use IE11、Edge、Chrome
I got txdlog.txt and client_socket.log
which line I need to check?
I open SWIM.properties and check activeworkspace.enabled=true
and....than?
I can see SW file in ActiveWorkspace and open it, but I can't see Activeworkspace page in SW.
best
Solid Edge ST10
Please send me the logs and I'll take a peek!
Peter Heath
ITI - International TechneGroup
+1-734-678-5302 | Mobile
peter.heath@iti-global.com
www.iti-global.com<>
CONFIDENTIALITY NOTICE: This email message and any attachments to it, is intended only for the individual or entity to which it is addressed and may contain confidential material. If you are not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, please do not disclose, copy, forward, or retain. If you have received this in error, please contact the sender by reply email, erase the original message from your computer system, and destroy all copies of the original message. Thank You.
Hello PeterH
there is log file
This is test environment
NO in include confidential file
Solid Edge ST10
Hi
  In the txdlog file we dont see the line
activeworkspace.enabled = true
The only entry from swim.properties we see is "checkout.exportdirectory = C:\SWstartwork"
It looks like you are not using the swim.properties file that you this is being used.  All of the values you set in swim.properties will be echoed into the txdlog.txt file.
Hope this helps.
  - Peter
So,you mean I need to check swim.proppertis ?
This is my swim.proppertis file
Which one I need to change?
thanks!!
Solid Edge ST10
Hi
  After installing SWIM, you need to configure the options you need in SWIM.Properties and SWIM.XML.
All of the lines in swim.properties that have a # as the first character are comments.  If you want to make a change in a value active, you need to have it on a line without the #.
So, I would recommend adding the line
as the next line under the the exportdirectory line.
We provide a service called Quickstart that guides cusomters through the process of using Teamcenter, Creo/Solidworks and the CAD integration together.  There are many congiruation points in these combinations.
 Peter
