Add Properties in the Audit Report in TC 11.3
HI,
I'm trying to add more fields the workflow audit included in Summary Tab.
I added in the rule  TC_10_Crf_Audit_WF_TIE properties fnd0AliasTaskName and fnd0Assignee and then I added them to the XMLRenderingStyleSheet the columms are in the audit but in blank.
What's the way to have this fields in my audit?
Re: Add Properties in the Audit Report in TC 11.3
@Malmi
Unless I'm missing something, the only properties you can add to display are ones that reside on the business object Fnd0WorkflowAudit.
And, in BMIDE, these properties dont reside on the the audit, they reside on the object EPMTask.
Richard
www.prospectplm.co.uk
Richard Bennett
PLM Consultant
www.ProspectPLM.co.uk
Is there a way  using Closing rules?
Possibly.  The report just uses a Property Set retrieving values for properties on Fnd0WorkflowAudit.  You could try creating a Closure Rule that navigated to the EPMTask and then add your EPMTask properties to the Property Set.
The report uses TCXML, so the Closure Rule will have to be TCXML.
Richard Bennett
PLM Consultant
"The report uses TCXML, so the Closure Rule will have to be TCXML."
Could you please explain me better this choice?
see attached.
Richard
Richard Bennett
PLM Consultant
