Adding fixes attributes to items
Hi guys,
There are eome attributes the user adds to all items he creates.
The values change in different parts but the attribute is the same.
Like "Material", "Part Type" , "Manufacturing Order", "Cost" etc
User wants these attributes to be created when he creates an item.
Is this done via BMIDE?
Is there a tutorial?
Cem
Re: Adding fixes attributes to items
In BMIDE
- create a project to hold the custom item type
- create a sub-type of an Item.
- add the attributes you need
- package your project
- deploy using Environment Manager (tem.bat).
TEM deploy is recommended for data model modification.  Hot deploy can be used for LOV (List of Values) modification.  BMIDE guide goes in depth.
Thank you very much!
Cem ALPAY
Yönetici
Üçgen Yazılım Ltd. Şti.
--Iphone'umdan gönderildi--
