Admin Data Documentation Report, Compare Report utilites
Hi All,
I want to try the Admin data documentation report and compare report utilites.
Request your inputs on how to run these utilities and get the output in html.
Phani
Re: Admin Data Documentation Report, Compare Report utilites
Hi Phani,
generate_admin_data_compare_report in TC_BIN generates the below report in html format. Inputs to it are source and target packges (that you could generate from TEM)
This is the command line (for example I used the same package as source and target):
generate_admin_data_compare_report -u=infodba -p=xxxx -g
=dba -sourcePackage=C:\OFS\administration_data.zip -targetPackage=C:\OFS\administration_data.zip -adminDataTypes=all -outputDir=C:\OFS\outputDir
index.html will be in outputDir.
Best Regards
Harish
Thanks Harish for your inputs. Generated the report.
Phani
