An error occurred while evaluating a condition. Unable to determine applied templates teamcenter12
This is the last step in the TEM to create the WAR.file and I have tried troubleshooting the best I can, but not getting past this error.
I have tried troubleshooting by solution: Admin had to restart flex license service, Siemens PLM License Server.
I have attached the logs for anyone to look at.
Thanks!
Re: An error occurred while evaluating a condition. Unable to determine applied templates teamcenter
Good afternoon, try the solution from the Solution Center:
https://solutions.industrysoftware.automation.siemens.com/
Search:
