Any possibility to do Auto login in Teamcenter Rich Client
Is there any possibility to do login automatically in Teamcenter rich client by passing the user name and password through batch or other sources.
For example in NX, To launch the Teamcenter integrated NX I can pass the user name and password to make auto login.
call %UGII_ROOT_DIR%\ugraf.exe -pim:yes -u=user -p=P@ssword
Selvaraj C
CAD Automation Engineer
NX 9 | NX 11 | Teamcenter 10
9 REPLIES 9
Re: Any possibility to do Auto login in Teamcenter Rich Client
-Dautologin.user=<user> and -Dautologin.pass=<password> as JVM parameters
Hello, where do we enter this line?
You have to supply as input argument for teamcenter.exe in portal.bat. Both arguments must be pass as vmargs.
:: example script.
start Teamcenter.exe %* -vm "%JRE_HOME%\bin\javaw.exe" -vmargs -Dautologin.user=<user> -Dautologin.pass=<password>
Selvaraj C
How to specify the server to use for autologin if multiple ones are available?
You don't login to a server, you login to a Teamcenter environment. I guess I don't understand your question?
Evaluating: AW 3.4
server := Teamcenter server := Teamcenter server environment
Also can we specify the membership group, default role and the revision rule as well?
As I noticed on GTAC - autologin capability assume that user_id and pass are equals wih OS user and OS pass.
There are no possibility to use autologin with TC credentials only like a running NX with -pim=yes -u -p -g
Dear All,
How to pass Group and Role information along with this ? i am able to auto login with below line, but i also want Group and Role to be taken while login.
start Teamcenter.exe %* -vm "%JRE_HOME%\bin\javaw.exe" -vmargs -Dautologin.user=infodba -Dautologin.pass=abcd+123  -Xmx%VM_XMX% -XX:MaxPermSize=128m -Xbootclasspath/a:"%JRE_HOME%\lib\plugin.jar";"%JRE_HOME%\lib\deploy.jar";"%JRE_HOME%\lib\javaws.jar" %DJIPJL_VMARG%
