Applying patch Tc8.3.3.9_i01_patch_5_wnti on TC 8.3 - TC fails to launch
Need help on this issue.
I tried the below:-
Test Case 1:-
  1. I installed TC 8.3 with Foundation + TCII + CMM templates.
  2. I then applied the patch Tc8.3.3.9_i01_patch_5_wnti.
  3. Did the post patch update process of updating tcdata.
Test Case 2:-
  1. I installed TC 8.3 with Foundation template.
Now I am unable to login to TC. I tried with Java/JRE 1.6.14 and 1.7.0_21/51 but getting Java NULL pointer Exception.
Re: Applying patch Tc8.3.3.9_i01_patch_5_wnti on TC 8.3 - TC fails to launch
Siemens Legend Siemens Legend
Siemens Legend
did both test cases end up with the null pointer exception?
seems like a file in the portal\plugins directory got corrupt?!?
have you tried to run genregxml.bat?
Thanks...somehow it got resolved. Restarted the system and issue was not there.
