Audit Manager
Builder
Builder
By default, teamcenter has tracking deleted events in the system.log (%TC_DATA%/log_%host%_%db%/system.log) file. How do we enable audit for other events like Check-Out,Check-in,Modify events?
Re: Audit Manager
Which Teamcenter version are you using?
What is value for below preferences?
TC_audit_manager
TC_audit_manager_version
Ideally, it should log for all events.You may share scenario for which it is not working.
Re: Audit Manager
Builder
Builder
@akash4plm,
TC_audit_manager: default value is OFF, i have made it ON, when i try to login, giving an error like teamcenter detected serious internal error.
TC_audit_manager_version; Value is empty.
Now,its recording deleted events only.Refer the screenshot.
Re: Audit Manager
What is Teamcenter Version? I assume it is either 10 or earlier.
You need to set both preferences listed below:
TC_audit_manager=ON
TC_audit_manager_version=2 [ If Teamcenter version is 10 or earlier.], preferrably 3.
Setting value to 3 will display audit log in Summary Tab. It will generate audit log in database.
I think, Error you are getting is becuase Teamcenter expects value for TC_audit_manager_version too.
