Automatic form name preference
I would like to know how to generate automatic names for forms under an ItemRevision. I used this site preference
TCAE_autogen_name_form_types
But its not generating the form name. It says value should be valid Teamcenter form type. My question is, has it got something to do with real name (in BMIDE) or display name.
Hoping to get answer.
Thanks a lot.
Srinidhi
TC9.1 TC 11.2
NX 8.5 NX 10
5 REPLIES 5
Re: Automatic form name preference
Hello all,
I found out that TCAE_autogen_name_form_types need auto_edition/gm_overlay license. So is there any other way in BMIDE to set object_name property / operations that it automatically take the name from Itemrevision in such a way that
{%item_id}/{%item_revision_id}-Form
So please let me know. I would be happy on any input.
regards,
Srinidhi
Did you try InitialValue constant on Object_name property of the FORM
Naveen
hello,
This InitialValue makes all the form names constant. I want it to be controlled over an arg LOV
Like %item_id/Item_revision_id%-%form_type%
Is this possible?
Srinidhi
Srinidhi,
You can make form name dyanamic
You can try like below expression, provided those attributes exist on your custom form
Initial value= $Item_id/$item_revision_id/$Object_type
If properties does not exist, see if you can make compound property on your Form.
Naveen
Hello @naveengm
This doesnt work, as initial value is not runtime property. Its fixed value for the form.
I found a solution for this. I might use TCAE_autogen_name_form_types with gm_overlay license.
That works.
Srinidhi
