BMIDE -Engineering Utility Failure
I had BOMIDE with LOV, Item rev master properties, UOM. deployed successfully.  We are not able to display UOM description, We deleted all UOM and Created UOM by LOV to display description UOM. When I deploy, I got the Engineering Utility Failure Error.
install_GoodmanTest_1709281138.log
**************************** INSTALL BEGINS *****************************
Time of Install: Thu Sep 28 11:38:49 CDT 2017
Operating System: Windows NT (unknown)
OS Version: 6.2
User Name: TCAdmin
User Home: C:\Users\TCAdmin
Application: tceng
Application Version:9000.1.0.33
No debugging options are enabled
No defaults files are in use
The following Teamcenter-related environment variables were set when TEM was launched
PATH =
  C:\Windows\system32
  C:\Windows
  C:\Windows\System32\Wbem
  C:\Windows\System32\WindowsPowerShell\v1.0\
  C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\
  C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\ManagementStudio\
  C:\Program Files\Microsoft SQL Server\120\Tools\Binn\
  C:\Program Files (x86)\Microsoft SQL Server\120\DTS\Binn\
  C:\Program Files\Microsoft SQL Server\120\DTS\Binn\
  C:\Program Files\Siemens\Teamcenter9.1\Visualization\Products\Mockup\ClearanceDB
PATHEXT = ".COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC"
TEMP = "C:\Users\TCAdmin\AppData\Local\Temp"
TEM_SPLASH = "-splash:./install/Splash.jpg"
TMP = "C:\Users\TCAdmin\AppData\Local\Temp"
UGS_LICENSE_SERVER = "28000@DPITCenterLM"
Operation:  Install Mode
Config ID: GoodmanTest
Recovery Mode? false
Maintenance Mode? true
Features currently installed
 VC 2005/2008 Redistributables
 FMS Server Cache
 Teamcenter Foundation
 NX Integration
 Client Communication System
 2-tier server configurations
 JtUtilities Support
 Teamcenter Rich Client 2-tier
 Business Modeler IDE
 Teamcenter Visualization (Embedded) for Rich Client
 Business Modeler Templates
 Business Modeler IDE Standalone
 Online Help
 .NET Based Server Manager
 Solid Edge Embedded Client Overlay/Solid Edge Embedded Client Overlay
 dktest/Data Model
 Sample files
 Teamcenter Extensions for Microsoft Office
 Teamcenter Client for Microsoft Office
 DaikinProdTC/Data Model
 testtbd/Data Model
Features to be added
 None
Features to be removed
 None
Features to be deprecated
 None
Loading C:\Siemens\Teamcenter9\install\uninstall.xml
Processing <maintenance> feature Teamcenter Foundation
Time: Thu Sep 28 11:38:50 CDT 2017
*** Processing block Teamcenter Foundation/maintenance:0
Running com.teamcenter.install.tceng.base.DatabaseSteps
*** Running com.teamcenter.install.tceng.base.DatabaseSteps
Updating database
Setting up Teamcenter shell
Executing [set IMAN_ROOT=C:\Siemens\Teamcenter9]
Executing [set IMAN_DATA=C:\Siemens\tcdata]
Executing [set TC_ROOT=C:\Siemens\Teamcenter9]
Executing [set TC_DATA=C:\Siemens\tcdata]
Executing ["C:\Siemens\tcdata\tc_profilevars"]
Output from command:  "C:\Siemens\tcdata\tc_profilevars"
command_exit=0
Exit Status  0, elapsed time 0:00:00
Executing [set TNS_ADMIN=C:\Siemens\tcdata]
Executing [set IMAN_BYPASS_CANNED_METHODS=ALL]
Executing [set BYPASS_RULES=ON]
Executing [set NR_BYPASS=ON]
Executing [set BMF_BYPASS_ALL_EXTENSION_RULES=ON]
Executing [set TC_USE_METADATA_SHARED_MEMORY=FALSE]
Executing [set TC_KEEP_SYSTEM_LOG=true]
Executing [set IMAN_KEEP_SYSTEM_LOG=true]
Executing [set IMAN_TMP_DIR=C:\Siemens\Teamcenter9\logs]
Executing [set TC_TMP_DIR=C:\Siemens\Teamcenter9\logs]
Executing [set LANGID=EN]
Executing [cd /D "C:\Siemens\Teamcenter9\logs"]
Output from command:  cd /D "C:\Siemens\Teamcenter9\logs"
command_exit=0
...Done
Updating database:  full model deploy
Executing ["C:\Siemens\Teamcenter9\bin\manage_model_files.exe" -u=infodba -p=***** -g=dba -force=model -option=download]
Output from command:  "C:\Siemens\Teamcenter9\bin\manage_model_files.exe" -u=infodba -p=***** -g=dba -force=model -option=download
Downloading File: model.xml
Downloading File: model_lang.xml
command_exit=0
Exit Status  0, elapsed time 0:00:07
Deploying daikinprodtc to TC_ROOT
Adding search path: C:\tcinstall\Teamcenter 9 Base\Tc9.1_base_64bit\tc
Copying file C:\Siemens\Teamcenter9\bmide\workspace\Production\DaikinProdTC\output\wntx64\packaging\full_update\2017_09_28_11-36-49\feature_daikinprodtc.xml to C:\Siemens\Teamcenter9\install\install\modules\feature_daikinprodtc.xml
Copying file C:\Siemens\Teamcenter9\bmide\workspace\Production\DaikinProdTC\output\wntx64\packaging\full_update\2017_09_28_11-36-49\daikinprodtcBundle_en_US.xml to C:\Siemens\Teamcenter9\install\daikinprodtc\daikinprodtcBundle_en_US.xml
Copying file C:\Siemens\Teamcenter9\bmide\workspace\Production\DaikinProdTC\output\wntx64\packaging\full_update\2017_09_28_11-36-49\daikinprodtc_icons.zip to C:\Siemens\Teamcenter9\install\daikinprodtc\daikinprodtc_icons.zip
Executing [echo n | "C:\Siemens\Teamcenter9\install\install\unzip" -o -d"C:\Siemens\Teamcenter9" "C:\Siemens\Teamcenter9\bmide\workspace\Production\DaikinProdTC\output\wntx64\packaging\full_update\2017_09_28_11-36-49\daikinprodtc_install.zip"]
...8 files
Executing [echo n | "C:\Siemens\Teamcenter9\install\install\unzip" -o -d"C:\Siemens\Teamcenter9" "C:\Siemens\Teamcenter9\bmide\workspace\Production\DaikinProdTC\output\wntx64\packaging\full_update\2017_09_28_11-36-49\daikinprodtc_template.zip"]
...3 files
Copying file C:\Siemens\Teamcenter9\bmide\workspace\Production\DaikinProdTC\output\wntx64\packaging\full_update\2017_09_28_11-36-49\client_daikinprodtc.properties to C:\Siemens\Teamcenter9\install\daikinprodtc\client_daikinprodtc.properties
Copying file C:\Siemens\Teamcenter9\install\daikinprodtc\client_daikinprodtc.properties to C:\Siemens\tcdata\model\client_daikinprodtc.properties
Deploying daikinprodtc to TC_DATA
Copying file C:\Siemens\Teamcenter9\install\daikinprodtc\daikinprodtc_template.xml to C:\Siemens\tcdata\model\daikinprodtc_template.xml
Copying file C:\Siemens\Teamcenter9\install\daikinprodtc\daikinprodtc_dependency.xml to C:\Siemens\tcdata\model\daikinprodtc_dependency.xml
Copying directory C:\Siemens\Teamcenter9\install\daikinprodtc\lang to C:\Siemens\tcdata\model\lang
Copying file C:\Siemens\Teamcenter9\install\daikinprodtc\daikinprodtc_icons.zip to C:\Siemens\tcdata\model\icons\daikinprodtc_icons.zip
Executing [business_model_extractor -u=infodba -p=***** -g=dba -outfile="C:\Siemens\tcdata\model\model.xml"]
Output from command:  business_model_extractor -u=infodba -p=***** -g=dba -outfile="C:\Siemens\tcdata\model\model.xml"
Extracting....
Extraction Completed.
Extracting Localizations....
Localization Extraction Completed.
Please refer [C:\Siemens\Teamcenter9\logs\business_model_extractor_2017_09_28_11-39-03.log] for log information
command_exit=0
Exit Status  0, elapsed time 0:03:48
Executing ["C:\Siemens\Teamcenter9\bin\bmide_processtemplates.bat" -u=infodba -p=***** -g=dba -mode=server -dir=C:\Siemens\tcdata\model -templates=daikinprodtc -deployvalidation=yes -update=all ]
Output from command:  "C:\Siemens\Teamcenter9\bin\bmide_processtemplates.bat" -u=infodba -p=***** -g=dba -mode=server -dir=C:\Siemens\tcdata\model -templates=daikinprodtc -deployvalidation=yes -update=all
Validating for deployment
Fetching deployment information for template daikinprodtc
 A report has been generated in the file C:\Siemens\tcdata\model\installed_template_info.properties.
Fetching site information
 File  siteinfo.properties is created in the path C:\Siemens\tcdata\model
Adding Template to Master File...
Backing up the Consolidated Model File...
Backing up the Consolidated Model Localization File...
Finding Applicable Locales...
Creating the Consolidated Model File...
Creating the Localization Consolidated Model File...
Loading the Backup File...
Loading the Consolidated File...
Comparing the two Files...
Creating the Delta file...
Comparing the two Localization Files...
Creating the Localization Delta file...
**The backup of all files used for delta generation is available in C:\Siemens\Teamcenter9\logs\compare_history\update\model_compare_2017_09_28_11-43-53.zip
Uploading the files to Database...
Processing File: daikinprodtc_template.ref
Processing File: daikinprodtc_template_en_US.ref
Processing File: daikinprodtc_dependency.xml
Processing File: daikinprodtc_template.xml
Processing File: master.xml
Processing File: model.xml
Processing File: daikinprodtc_template_en_US.xml
Processing File: model_lang.xml
Running command (icons): C:\Siemens\Teamcenter9\bin\manage_icon_files -u=infodba -p=infodba -g=dba -option=upload -template=daikinprodtc -refDir=C:\Users\TCAdmin\AppData\Local\Temp\c61c1815_15ec_95f8_a3ca_a8248d9715124
Archive:  C:/Siemens/tcdata/model/icons/daikinprodtc_icons.zip
  inflating: C:/Siemens/Teamcenter9/logs/59cd26db00000c54000077f6/daikinprodtc/master_icon.xml
No icons files to upload for daikinprodtc template
Uploading daikinprodtc_icons.zip
Uploading daikinprodtc_icons.zip.ref
Uploading the project backup files to Database...
There are no project backups to upload to the Database
Done
command_exit=0
Exit Status  0, elapsed time 0:01:28
Database Update Section:  Database Prep
Processing 3 POM commands
command_exit=0
Executing [set DBPLAT=MSSQL]
Executing [set TC_DB_PLATFORM=MSSQL]
command_exit=0
...Done
**  Running command 1 of 3
Executing [install -regen_schema_file infodba ***** dba >>"C:\Siemens\Teamcenter9\logs\tc_install.log"]
Output from command:  install -regen_schema_file infodba ***** dba >>"C:\Siemens\Teamcenter9\logs\tc_install.log"
command_exit=0
Exit Status  0, elapsed time 0:00:02
**  Running command 2 of 3
Executing [install -lock_db infodba ***** dba >>"C:\Siemens\Teamcenter9\logs\tc_install.log"]
Output from command:  install -lock_db infodba ***** dba >>"C:\Siemens\Teamcenter9\logs\tc_install.log"
command_exit=0
Exit Status  0, elapsed time 0:00:01
**  Running command 3 of 3
Executing [clearlocks -assert_all_dead infodba ***** dba >>"C:\Siemens\Teamcenter9\logs\tc_install.log"]
Output from command:  clearlocks -assert_all_dead infodba ***** dba >>"C:\Siemens\Teamcenter9\logs\tc_install.log"
command_exit=0
Database Update Section:  Utilities
Loading use file C:\Siemens\Teamcenter9\install\daikinprodtc\install_daikinprodtc.default
Database Update Section:  updater
Processing 1 POM commands
command_exit=0
command_exit=0
...Done
**  Running command 1 of 1
Executing [business_model_updater -u=infodba -p=***** -g=dba -update=all -mode=upgrade -predelta -file=C:\Siemens\tcdata\model\delta.xml]
Output from command:  business_model_updater -u=infodba -p=***** -g=dba -update=all -mode=upgrade -predelta -file=C:\Siemens\tcdata\model\delta.xml
ERROR: Unprocessed schema and/or non-schema updater transactions exist.
ERROR: Please see updater log at C:\Siemens\Teamcenter9\logs\business_model_updater_2017_09_28_11-44-22.log for status of unprocessed element(s).
Processing localizations...
Please see updater log at C:\Siemens\Teamcenter9\logs\business_model_updater_2017_09_28_11-44-24.log for status of processed element(s).
command_exit=226007
Exit Status  226007, elapsed time 0:00:09
Utility failed. Make a second attempt to generate more detailed log files.
Executing [set UGII_DEBUG_LEVEL=1]
Executing [set TC_TRACEBACK=ON]
Executing [set TC_SQL_DEBUG=J]
Executing [set TC_POM_JOURNALLING=N]
Executing [set TC_JOURNALLING=ON]
Executing [set TC_JOURNAL_MODULES=ALL]
Executing [set API_JOURNAL=FULL]
Executing [set TC_JOURNAL=FULL]
ERROR: Please see updater log at C:\Siemens\Teamcenter9\logs\business_model_updater_2017_09_28_11-44-37.log for status of unprocessed element(s).
Please see updater log at C:\Siemens\Teamcenter9\logs\business_model_updater_2017_09_28_11-44-39.log for status of processed element(s).
command_exit=226007
Exit Status  226007, elapsed time 0:00:15
A POM utility has failed with status 226007
Capturing all related logs and information available: Thu Sep 28 11:44:39 CDT 2017
Generating list of the latest logs
List of logs generated...list contains 5 log(s)
Attempting to access latest version of 'C:\Siemens\Teamcenter9\install'
Latest version available: C:\Siemens\Teamcenter9\install\install_GoodmanTest_1709281138.log
Adding installation log to the list of related logs
Please review the following logs for more details:
Converting list of logs to an array
Command business_model_updater -u=infodba -p=infodba -g=dba -update=all -mode=upgrade -predelta -file=C:\Siemens\tcdata\model\delta.xml failed with status 226007
Releasing the command shell
Generating exception: Thu Sep 28 11:44:42 CDT 2017
An error occurred during execution.  Stack trace follows...
com.teamcenter.install.tceng.base.DatabaseSteps.processCommands(DatabaseSteps.java:933)
com.teamcenter.install.tceng.base.DatabaseSteps.rerunTemplateDefaults(DatabaseSteps.java:2572)
com.teamcenter.install.tceng.base.DatabaseSteps.updateDatabaseAll(DatabaseSteps.java:2254)
com.teamcenter.install.tceng.base.DatabaseSteps.updateDatabase(DatabaseSteps.java:2216)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
java.lang.reflect.Method.invoke(Method.java:597)
com.teamcenter.install.tem.tasks.JavaTask.execute(JavaTask.java:209)
com.teamcenter.install.tem.tasks.Task.execute(Task.java:114)
com.teamcenter.install.tem.tasks.blocks.CodeBlock.execute(CodeBlock.java:140)
com.teamcenter.install.tem.struct.TcFeature.processAction(TcFeature.java:1291)
com.teamcenter.install.tem.struct.TcFeature.process(TcFeature.java:1230)
com.teamcenter.install.tem.struct.TcFeature.maintenance(TcFeature.java:986)
com.teamcenter.install.tem.director.actions.MaintenanceAction.execute(MaintenanceAction.java:30)
com.teamcenter.install.tem.director.DirectorScript.execute(DirectorScript.java:115)
com.teamcenter.install.tem.director.Director.run(Director.java:101)
java.lang.Thread.run(Thread.java:619)
Please help to resolve the issue
Re: BMIDE -Engineering Utility Failure
you should see more about the error in the logfile
And in the delta.xml you can see the model differences what the updater wants to change
I am not able to make anything from those files, Anything particularly, I need to look
can you attach the files I mentioned?
Roman65
Please find the attached files.
Thanks for help
Venny
need one more log file
The one you attached is the update of localization, which was successful
Roman65
Please find the attached files. please let me know, if you need any more info
Venny
you have used the deployed UnitOfMeasures on Items?
That's why you cannot delete them.
logfile
Delete | TcUnitOfMeasure| V5BU                           |  515110 | The instance is referenced.
Delete | TcUnitOfMeasure| V5BX                           |  515110 | The instance is referenced.
Delete | TcUnitOfMeasure| V5CM                           |  515110 | The instance is referenced.
Delete | TcUnitOfMeasure| V5CN                           |  515110 | The instance is referenced.
Delete | TcUnitOfMeasure| V5EA                           |  515110 | The instance is referenced.
Delete | TcUnitOfMeasure| V5MG                           |  515110 | The instance is referenced.
You need to remove the UnitOfMeasures on the Item, where you have used them.
After that you can redeploy your template
BR
Roman
You need to remove the used UnitOfMeasures
The log indicates that you are trying to delete some UnitOfMeasure definitions ( V5BU,V5BX,V5CM,V5CN,V5EA,V5MG etc) as part of this deploy and there are some instances referring these UoMs.
You can search for these UoMs in RAC (or any other client) and find the instances that are referring them to take the appropriate action.
Thank you Roman65 and Appechar for helping me out. Yes Based on your guidence, I searched, deleted few item which had UOM, converted other items of UOM to each(default), see the report all item on UOM, everywhere it shows each. attached search screen also for your reference.
small description of what happened
I had added UOM. deployed successfully. As you per management suggestion, We deleted all UOM and Created DUOM by LOV to display description UOM. When I deploy, I got the Engineering Utility Failure
Cleared all DUOM  and attached report also.
I searched by UOM(by query builder), it was bringing few, after changing, now it is clear.
All after effort, I got below errors. now reduced to only 3 from 6.
Unprocessed Non-Schema Changes:
Action | Element Type | Element Name | Error # | Error
How to clear this three? any help is appreciated.
Thank you all for you help and support,
Venny
