BMIDE Item Revision Master- Adding new property
When I try to add Property to Item Revision Master, It shows the error "Active Release not set"
what is the mean? how to resolve? Just restored the test server.
Please help
Venny
3 REPLIES 3
Re: BMIDE Item Revision Master- Adding new property
Any thoughts!
Deleted the project and imported from backup, it work fine.
Venny
Hello Venny,
the solution is easier than you think:
1) In BMIDE, go to the Extensions tab
2) than Expand: Project --> Code Generation --> Releases and Select the appropriate release
3) Right-Click --> Organize --> Set as active release.
Now try to re-add your custom property.
