BMIDE deployment error TC11
While deploying custom templete in BMIDE following error found
Deploy Data Model Failed
Reason: the file fileversion.txt could not be opened for writing
Please help me on the same.
Thank you in advance
Re: BMIDE deployment error TC11
Hello mith, try run bmide as administrator rights and check the directory permission where fileversion.txt is located
Rename the fileversion.txt file and run it again.
Hello guys ,
After renaming is the problem solved or not ? Could you inform us plz. because i have the same problem but i can not solve it .
