BMIDE deployment error TC11
While deploying custom templete in BMIDE following error found
Deploy Data Model Failed
Reason: the file fileversion.txt could not be opened for writing
Please help me on the same.
Thank you in advance
3 REPLIES 3
Re: BMIDE deployment error TC11
Hello mith, try run bmide as administrator rights and check the directory permission where fileversion.txt is located
Rename the fileversion.txt file and run it again.
Evaluating: AW 3.4
Hello guys ,
After renaming is the problem solved or not ? Could you inform us plz. because i have the same problem but i can not solve it .
