BMIDE not showing "Package Template Extensions"
I have fresh out of the box Teamcenter and a new BMIDE project. All looks good but the option to "Package template extensions" is not an option.
Any ideas?
Re: BMIDE not showing "Package Template Extensions"
It has been renamed to "Generate Software Package" in recent versions.
Perfect thanks,
I have managed to deploy the BMIDE template into TEM but it does not show in the templates when I go to update Database (Full update system downtime required). Any ideas?
Hi @Tom189 ,
You can follow below instructions to deploy your template.
https://docs.plm.automation.siemens.com/tdoc/tc/11.2/help/#uid:c03a002
There are 2 different method for deployment of template. One of is called as Hot Deploy and the other one is called as Cold Deploy. But generally i use the above link .
Best Regards
Gurkan
