BMIDE template creation failure
Builder
Builder
Hi team,
We are trying to upgrade BMIDE template of TC10 in TC12, but we are unable to upgrade the template successfully in BMIDE->upgrade tool->preference migration.
Below are the detailsls from the console log.
Attached is the screenshot of the error message.
Date: 06-Aug-2019_23-36-39
Loading project: "m6mmiacdcust"
Model Error: C:\Siemens\Teamcenter12\bmide\templates\foundation_template.xml Line:46284 Column:165 Command execution failed. ( Template Name : "foundation" )
Model Error: C:\Siemens\Teamcenter12\bmide\templates\foundation_template.xml Line:46285 Column:157 Command execution failed. ( Template Name : "foundation" )
Model Error: C:\Siemens\Teamcenter12\bmide\templates\foundation_template.xml Line:46380 Column:307 Invalid Query String: "SELECT qid FROM ADA_License WHERE "id"^ IS_NOT_NULL "IS_NOT_NULL"". ( Template Name : "foundation" )
Date: 06-Aug-2019_23-37-23
Date: 06-Aug-2019_23-39-39
Date: 06-Aug-2019_23-40-16
Re: BMIDE template creation failure
are you pointing to the correct template folder for your Tc12 bmide installation?
Check %TC_ROOT%\bmide\templates if you can find "foundation.xml"
