BOM Compare Customization
Hello All,
TC Version - 8.3
Requirement is to compare the selected Item Revison's BVR to its previous released BVR and generate the report with differences which includes changes in BOM Lines and also attribute value changes if any. So we need to add more attributes to the scope of comparison for the OOTB BOM Compare.
Has anyone customized BOM Compare , Could you please share what would be the better solution approach to implement this.
TIA.
Re: BOM Compare Customization
What solution aproach have you implemented?
