BOM - SOA get BOMWindow with packed BomLines
Hi, comunity
I' m programing a software to get from TeamCenter via SOA an item/revision BOM.
My code in C# is this:
using System;
using Teamcenter.Soa.Client.Model;
using Teamcenter.Soa.Client.Model.Strong;
using Teamcenter.Services.Strong.Cad._2007_01.StructureManagement;
using Teamcenter.Soa.Exceptions;
using Teamcenter.Services.Strong.Core;
using Teamcenter.Soa.Common;
using System.Data;
namespace SOA_Interface_Test.logical
    class ShowBOM
        private String ItemUID;
        private String ItemRevUID;
        private DataTable BOMListTable;
        private BOMWindow bomWindow = null;
        private DataManagementService dmService;
        private Teamcenter.Services.Strong.Cad.StructureManagementService smService;
        private Item item;
        public ShowBOM()
            dmService = DataManagementService.getService(Teamcenter.ClientX.Session.getConnection());
            smService = Teamcenter.Services.Strong.Cad.StructureManagementService.getService(Teamcenter.ClientX.Session.getConnection());
            BOMListTable1 = new DataTable();
            BOMListTable1.TableName = "BOM_LIST_TABLE";
            SetColumns(BOMListTable1);
        public string ItemUID1 { get => ItemUID; set => ItemUID = value; }
        public string ItemRevUID1 { get => ItemRevUID; set => ItemRevUID = value; }
        public DataTable BOMListTable1 { get => BOMListTable; set => BOMListTable = value; }
        public bool loadItem()
            ServiceData sData = dmService.LoadObjects(new String[] { ItemUID1 });
            if (sData.sizeOfPlainObjects() > 0)
                ModelObject mObj = sData.GetPlainObject(0);
                if (mObj is Item)
                    item = (Item)mObj;
                    //Properties ofBOMList
                    dmService.GetProperties(new ModelObject[] { mObj }, new String[] { "bom_view_tags", "revision_list" });
                    return true;
            return false;
        public bool showBOMWindowStructure()
            try
                ModelObject[] itemRevs = item.Revision_list;
                ModelObject[] bomViews = item.Bom_view_tags;
                foreach (ModelObject bomView in bomViews)
                    foreach (ModelObject itemRev in itemRevs)
                        CreateBOMWindowsInfo bomWinInfo = new CreateBOMWindowsInfo();
                            bomWinInfo.Item = item;
                            bomWinInfo.ItemRev = (ItemRevision)itemRev;
                            bomWinInfo.BomView = (PSBOMView)bomView;
                        CreateBOMWindowsResponse bomResp = smService.CreateBOMWindows(new CreateBOMWindowsInfo[] { bomWinInfo });
                        if (bomResp.Output.Length > 0)
                            BOMLine bomLine = bomResp.Output[0].BomLine;
                            expandBOMLines(bomLine);
            catch (NotLoadedException e)
                Console.WriteLine(e.Message);
            return false;
        public bool showBOMWindowStructure_ItemRev()
            try
                        if (ItemRevUID == itemRev.Uid)
                            CreateBOMWindowsInfo BOMWindows = new CreateBOMWindowsInfo();
                                BOMWindows.Item = item;
                                BOMWindows.ItemRev = (ItemRevision)itemRev;
                                BOMWindows.BomView = (PSBOMView)bomView;
                            CreateBOMWindowsResponse bomResp = smService.CreateBOMWindows(new CreateBOMWindowsInfo[] { BOMWindows });
                            bomWindow = bomResp.Output[0].BomWindow;
                            break;
            return false;
        private void expandBOMLines(BOMLine bomLine)
            ExpandPSOneLevelInfo  levelInfo = new ExpandPSOneLevelInfo();
            ExpandPSOneLevelPref levelPref = new ExpandPSOneLevelPref();
            levelInfo.ParentBomLines = new BOMLine[] { bomLine };
            levelInfo.ExcludeFilter = "None";
            levelPref.ExpItemRev = false;
            levelPref.Info = new RelationAndTypesFilter[0];
            ExpandPSOneLevelResponse levelResp = smService.ExpandPSOneLevel(levelInfo, levelPref);
            try
                LoadProperties(bomLine);
                PrintBomLine(bomLine);
                BomLineTable(bomLine, BOMListTable1);
            if (levelResp.Output.Length > 0)
                foreach (ExpandPSOneLevelOutput levelOut in levelResp.Output)
                    foreach (ExpandPSData psData in levelOut.Children)
                        expandBOMLines(psData.BomLine);
        private void LoadProperties(BOMLine bomLine)
            dmService.GetProperties(new ModelObject[] { bomLine }, new String[] {   "bl_line_name",
        "bl_item_object_name",
        "bl_is_last_child",
        "bl_formatted_parent_name",
        "bl_sequence_no",
        "bl_rev_vv4_tipo",
        "bl_level_starting_0"
        //muestra los datos de la bomline por consola
        private void PrintBomLine(BOMLine bomLine)
            Console.WriteLine("BOMLine: " + bomLine.Bl_line_name +
                                   "\t | Name: " + bomLine.Bl_item_object_name +
                                   "\t | Last_Child: " + bomLine.Bl_is_last_child +
                                   "\t | Formatted Parent Name: " + bomLine.Bl_formatted_parent_name +
                                   "\t | Sequence Number: " + bomLine.Bl_sequence_no +
                                   //propiedad definida (no está en el estándar de TC)
                                   "\t | Type: " + bomLine.GetPropertyDisplayableValue("bl_rev_vv4_tipo") +
                                   "\t | Type: " + bomLine.Bl_level_starting_0
        //exporta las properties de la bomLine a una datatable
        private void BomLineTable(BOMLine BOMLine, DataTable BomListTable)
            DataRow row;
            row = BomListTable.NewRow();
            row["BOMLINE_NAME"] = BOMLine.Bl_line_name;
            row["ITEM_NAME"] = BOMLine.Bl_item_object_name;
            row["LAST_CHILD"] = BOMLine.Bl_is_last_child;
            row["FATHER_NAME"] = BOMLine.Bl_formatted_parent_name;
            row["SEQU_NO"] = BOMLine.Bl_sequence_no;
            row["TYPE"] = BOMLine.GetPropertyDisplayableValue("bl_rev_vv4_tipo");
            row["LEVEL"] = BOMLine.Bl_level_starting_0;
            BomListTable.Rows.Add(row);
        private void SetColumns(DataTable BomListTable)
            DataColumn column;
            column = new DataColumn();
            column.DataType = System.Type.GetType("System.String");
            column.ColumnName = "BOMLINE_NAME";
            column.ReadOnly = true;
            column.Unique = false;
            BomListTable.Columns.Add(column);
            column.ColumnName = "ITEM_NAME";
            column.ColumnName = "LAST_CHILD";
            column.ColumnName = "FATHER_NAME";
            column.ColumnName = "SEQU_NO";
            column.ColumnName = "TYPE";
            column.ColumnName = "LEVEL";
I store the BOM in a DataTable and I get the Item/Rev from a query (wich is not in this code).
I get the BOM, but the lines are not packed. For example, i get this:
BOMLine: RT20150604000/c/CONJUNTO EJEMPLO (View)                                      //Level 0
BOMLine: RT20150604003/A0/PIEZA 3                                    -- Quantity 1            //Level 1
BOMLine: RT20141217001/--/Granpa(View)                          --  Quantity 1            //Level1
BOMLine: RT20141217003/--/Father (View)                             --  Quantity 1            //Level 2
BOMLine: RT20141217004/--/Son                                             --  Quantity 1           //Level 3
BOMLine: RT20150604002/--/PIEZA 2                                       --  Quantity 1           //Level1
BOMLine: RT20150602001/A0/PIEZA 1 REV2                           --  Quantity 1           //Level 1
And I want to get something like this:
BOMLine: RT20150604003/A0/PIEZA 3                                   -- Quantity 2            //Level 1
BOMLine: RT20150604002/--/PIEZA 2                                      --  Quantity 2           //Level1
Thank you so much!!
16 REPLIES 16
Re: BOM - SOA get BOMWindow with packed BomLines
You may want to try method StructureService.PackOrUnpack() to achive this.
Ok, I try to set BOM lines unpacked. I add this code to my expandBOMLines method:
using Teamcenter.Services.Strong.Structuremanagement;
private StructureService stService;
        public ShowBOM()
            stService = StructureService.getService(Teamcenter.ClientX.Session.getConnection());
private void expandBOMLines(BOMLine bomLine) { ExpandPSOneLevelInfo levelInfo = new ExpandPSOneLevelInfo(); ExpandPSOneLevelPref levelPref = new ExpandPSOneLevelPref(); levelInfo.ParentBomLines = new BOMLine[] { bomLine }; levelInfo.ExcludeFilter = "None"; levelPref.ExpItemRev = false; levelPref.Info = new RelationAndTypesFilter[0]; stService.PackOrUnpack(levelInfo.ParentBomLines, 1); ExpandPSOneLevelResponse levelResp = smService.ExpandPSOneLevel(levelInfo, levelPref); .......
But there is no changes in the result... Maybe I have not initzialice correctly the object? Or I have to use this in other place, not in the expand method??
Thank you so much.
As far as I understand, you want to PACK the lines, but the parameter value you gave in code is to unpack.
0:  pack the lines
1:  unpack the lines
2:  pack all lines
3:  unpack all lines
Also, according to what I understood from doc, you need to give Child-BOMlines when you want to pack and parent BOMLine as input when you want to unpack.
Use Cases:
User calls the operation with some lines to pack them, the lines will be packed.
User calls the operation with root line to unpack the whole structure, all loaded packed lines in the structure will be unpacked.
Also, I think you may have to call this function AFTER the BOMLine expansion has been done.
May be option 2 (pack all) and 3 (unpack all) will work with the root/parent BOMLine itself. I have never used this API, so just giving suggestions. I would be interested to know results of your tests.
If you use CreateBOMWindows2 then in the CreateWindowsInfo2 structure you pass to it you can set a number of flags in the BomWinPropFlagMap member.  One of the flags you can set is "is_packed_by_default".  Set this to "true" and your BOMLines should be packed for you.
Thank you for your response.
I tried to apply this solution:
  CreateWindowsInfo2 BomWindows2 = new CreateWindowsInfo2();
                                BomWindows2.Item = item;
                                BomWindows2.ItemRev = (ItemRevision)itemRev;
                                BomWindows2.BomView = (PSBOMView)bomView;
                                BomWindows2.BomWinPropFlagMap.Add("is_packed_by_default", true);
                            CreateBOMWindowsResponse bomResp = smService.CreateBOMWindows2(new CreateWindowsInfo2[] { BomWindows2 });
                            dmService.GetProperties(new ModelObject[] { bomWindow }, new String[] { "is_packed_by_default" });
                            Console.WriteLine("BOMWindow is packed: " + bomWindow.Is_packed_by_default);
When I get the value of "is_packed_by_default" key I see nothing changes:
BOMWindow is packed: False
 So, the BOMLines are not packed.
How can I pass the rootBomLine in the call?
The expandBOMLines method is a recursive algorithm. In the first call push the first BOMLine:
                                expandBOMLines(bomLine);  //ROOT BOM LINE??
In the call I try to call PackOrUnpack function with the Child Lines as parameter:
        private void expandBOMLines(BOMLine bomLine) //PARENT LINE
            stService.PackOrUnpack(levelInfo.ParentBomLines, 2);  //CHILD LINES??
So, What I am doing wrong??
Thank you so much.
Regards.
I think root bomline is nothing but the parent bomline, which you are already passing correctly.
According to the 1st use case specified in doc (User calls the operation with some lines to pack them, the lines will be packed.), I think child lines have to be passed to PACK. So may be you need to call packOrUnpack after ExpandPSOneLevel ??
Also, have you checked what is the outout coming from stService.PackOrUnpack() ? your code does not seem to capture output from this function.
I hope it works with these hints.
Ok, I modify my code, and I assing the PackOrUnpack() result to the ExpandPSOneLevelResponse levelResp  ServiceData property:
levelResp.ServiceData = stService.PackOrUnpack(levelInfo.ParentBomLines, 2);
I call the PackOrUnpack function after the ExpandPSOneLevel.
Is correct the argument levelInfo.ParentBomLines as BOMLine array in the PackOrUnpack call?
