BOMLine Default Quantity Value
Hello ,
I need your helps for BOMLine Default quantity value . As you know , when you send an item to Structure Manager and creating the BOM structure , bl_quantity value is comming blank as default. Then if i add the same item rev. double that value is setted as 2 . I don't know is it possible or not but , i want to see bl_quantity value as 1 as default. How can i manage it ? I hope , i explained it detailed.
Default Case ;
2018-10-17_21h42_18.pngRegards
Gurkan
Re: BOMLine Default Quantity Value
Hi ,
Do you want to show the value by default 1 here ? if so try to change the Property constant :Intial Value of this Property to 1  but this will affect the auto generation numbers .
You need to mnuallay change the number always.
