BVR - display rule
Currently if I clikc the BVR of Item, the latest structure of the Item is displayed in the structure manager.
Is it possible to change this behavior of BVR?
If it is changelable, which module do I have to configure such as BMIDE or revision rule?
Re: BVR - display rule
 Hi Gimec,
You can configure below preference ( DBA) to set default revision rule for Structure Manager based on your organisation Group/ Site/ User security.
Swapnil Gawas
Testing, Teamcenter 11.2.x | Active Workspace 3.x
Thank you so much. I can understand it.
Thank you for the quick reply.
