Bulk ownership change
Honored Contributor
Honored Contributor
Teamcenter 11.2.3.1
We have a family of NX hardware items, which I want to give ownership to dba, and they are currently a mix of users.  Is there a way to select every item in a folder, and change ownership of them all, to dba?
Currently, the only way I can do it, is to log on as each user, and transfer ownership.  If I change my role to dba, I am not allowed.  I have not tried by logging in as infodba
-Dave
Re: Bulk ownership change
Use the Bypass ON option as DBA.
Larry Carpenter, P.E.
Honored Contributor
Honored Contributor
Does this have to be full on infodba, or can I use this in the lesser user in the dba group?
and could you point me in the direction of where bypass is located?
-Dave
You can use this option for other members of the dba group, this does not have to be the user infodba
@DaveK
I recmond ,
Create a simple workflow with using handler EPM-change-ownership..
Initiate the workflow on the target objects.
this might help you.
