Business ITEM display Name
I want to modify the Display Name Business Constraint on a Custom business Item. The property value I would like to display is a property value attached to different ITEM.  object. Is there a way to display that property in the display name?
Re: Business ITEM display Name
The spelling of "object_name" in your image is wrong (the last 'e' is missing). Is that the actual problem ?
Hello
Assuming that your custom bussiness object is related to what you say a different ITEM by a relation or a reference property.
If so you can define a compound property on your custom business object traversing to the other item through relation/reference property.
Once you have the compound property, you can use it in your Display Name business object constant.
Mahendra
