Can curve face be save JT by creo integration?
Dear all
          I can save a JT from a part to Tc by Creo Integration ;
          Can I save JT from a surface along by the same way?
          The surface file was extracted from a part by me , 0 thickness.
Re: Can curve face be save JT by creo integration?
See Facet or BREP creation for Creo/JT:
https://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/data_exchange/interface/About_Imp...
Try creating a BREP JT.
Creo Settings (search for or add them in IPEM or Creo Translator configuration files):
https://support.ptc.com/help/creo/creo_pma/usascii/index.html#page/data_exchange%2Finterface%2Fabout...
Evaluating: AW 3.4
Hi  Randy
          Thanks for you reply;
          I have solved the problem by some means:
              1. get config file "pretojt.config" from ipem_install_dir/pejt;
              2.modify the file like this:
