Can't able to delete Item, getting error
Hello experts,
I am trying to delete a custom Item, But getting an error as " Referenced By ItemExportRecord" .
I am only the Owner of Item.
Thanks..
Re: Can't able to delete Item, getting error
You need to delete the references(s) first. Turn on where referenced pom in impact analysis, this will display the relations allowing you to select and delete them.
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/Where-Referenced-POM...
Richard Bennett
Richard Bennett
PLM Consultant
Prospect PLM Ltd
Tried with where referenced pom, can see it's Item and some question mark(?) and black rectangle s.
I tried to delete question mark symbol , got warning as it may jeopardize the system.
Show the print object view. Window;view;other;diagnostic
(Not at work, so not sure of exact name and location!)
When you pick each bull clip/?mark it will tell you exactly what it is. They will be the references and relations for the object e.g. folders where the object resides, specification relation to another object.
You can ignore the warning. But, if you arent convinced create a test item, put it in a folder and then try and delete the bull clips & ?marks.
Richard Bennett
www.prospectplm.co.uk
Richard Bennett
PLM Consultant
Prospect PLM Ltd
