Can't find the item and delete it !
Two weeks ago, I had deployed a template ,added a persistent property to the ItemRevision Mater form, Everything is OK. But a user using AddtoTeamcenter to import unmanaged documents to teamcenter. After the importing, He can't find the imported Item in teamcenter search box, and I create a new item using the same ItemID , The teamcenter tells me "finded a existing item". Actually, i can find the itemid form database table of "PITEM" . About ten items like this. How can i fix it? Thank for your help!
Teamcenter Express 5.3
Solidedge ST3
Re: Can't find the item and delete it !
Do the following checks in you database.
1. Check your itemid in "POM_KEY" table of your database and check the corresponding item UID in the PPOM_OBJECT table for owning site.
2. In RAC go to menu->windows->showview->printobjects. give the UID which you found in the obove step and see if you can able to load the object.
Prabhu
Thanks for your reply!
But in My Teamcenter Express,it have no "printobjects" view. In TC11, I found it,but i have no idea how to fix it or delete the ITEM.
