Can't link OTW page
Hello all
I am useing apache 2.4 for build otw
I am already build disserver and disserverstandce
And this is my apache's setting
Is it anything wrong?
And other things,I start
start_rmi
start_server
It seens doesn't work.
Where I can check  to solve the problem.
Thank you
Best Regards
David
Teamcenter 11.4,Active Workspace 3.4
Solid Edge ST10
Re: Can't link OTW page
Good afternoon, I do not have much experience with Apache, but you can try the following configuration for Apache:
documentroot "E:\Teamcenter11\webroot\disserverstance\webapp_root\otwweb"
DirectoryIndex otw.htm
<Directory
"E:\Teamcenter11\webroot\disserverstance\webapp_root\otwweb">
    allow from all
    order allow,deny
</Directory>
DirectoryIndex can also be changed in the Apache configuration, it should point to otw.html
Hello Arthur3
I check my httpd.conf.
I found I set wrong documentroot.
So I change set.
And problem solve.
Thank you for you respond.
Best Regards
David
Solid Edge ST10
