Can we change value of the TC_Allow_Longer_ID_Name in the preferences?
Builder
Builder
Hi All, When we create a dataset,it will take maximum of 128 characters and minimum of 32 characters for filename. I would like to change this as 25 Characters. Now,it can take only boolean values true or false. True means 128 characters and false means 32 characters of filename. Any suggestions...
Re: Can we change value of the TC_Allow_Longer_ID_Name in the preferences?
You could create a naming rule using regex to limit the string length.
Arden Bedell | Teamcenter Wonk | Applied CAx, LLC
