Can we check if a item contains a Identifier?
Good morning,
I would check if a item contains an associated identifier object "ID" associated in altid_list parameter. In this case, the Identifier and the revision are in the same level, and the revision has the ID associated too.
I tryied to find the altid_list property in a Item when I create a query in the query builder but I really don't know why it doesn't appear, neighter in itemRevision. I tried another options as to check global_alt_list and other parameters but I really don't know how to check "sons" of an item exists or not, or to find the altid_list property in item...
Any suggestion? ideas?
