Can we convert configuration of TC from NORMAL to PER_CLIENT?
Builder
Builder
Is there any way to change configuration from NORMAL to PER_CLIENT without reinstalling teamcenter?
Re: Can we convert configuration of TC from NORMAL to PER_CLIENT?
The right way to do it is using TEM. However, you can manually change it in TC_ROOT\iiopservers\tcserver.xml, change activation_mode. Make sure to validate that TC_ROOT\install\configuration.xml has the same info if you change it manually.
Evaluating: AW 3.4
Builder
Builder
@RandyEllsworth
Thank you. It Works.
