Change Server's Profile Name
After a successful installation that took some days, I realised that someone (not me) had chosen the server's name quite badly. I would like to change it to follow the company's server identification policy. Could someone tell me how to set it to another name? I mean the Server's field in the login to Teamcenter form.
Capture.PNGI would like to change the 'Server' field value.
 Thank you!
Re: Change Server's Profile Name
I guess this can be changed by changing "Connection Name" parameter which you can find with: launch TEM -> navigate to "Feature Maintenance" -> Select Modify 2-Tier/4-Tier Server settings -> click Next
Thank you very much, it worked like a charm!
Now the "Clarifying Names" policy is strictly followed.
Capture.PNGClarity is essential. Camelcase was used.
